当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
Carefully pull the central control cover up along its edges.
Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
Peel back the silver tape securing the ribbon cable to the cover.
Pull the small brown latch on the ribbon cable connector out.
Disconnect the ribbon cable to completely free the central control cover.
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
Gently slide the keyboard towards the display until the tabs on its front side are free.
Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
Use a spudger to gently lift the ribbon cable retaining flap.
Disconnect the ribbon cable.
Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
Remove the display assembly from the laptop.
Release the ribbon cable in the upper left corner of the laptop from its retaining tabs.
Use a spudger to unplug the speaker connector at the top center of the laptop.
De-route the speaker wires from their retaining tabs.
Use the flat end of a spudger to begin lifting the upper case at its front edge.
Lift the front edge of the case up until it comes free.
Work slowly and be sure not to get any cables caught in the upper case holes and guides.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
