跳转到主内容
简介
Use this guide to replace the optical drive in your Dell Inspiron 1525.
配件
没有特定配件。
  1. Locate the battery release switch on the bottom of the laptop.
    • Locate the battery release switch on the bottom of the laptop.
  2. Slide the battery release switch away from the lock symbol until you hear the battery click. Slide the battery towards the back of the laptop until it comes free.
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Remove the 5.75 mm #1 Phillips screw securing the optical drive. Pull the optical drive straight from the laptop.
    • Remove the 5.75 mm #1 Phillips screw securing the optical drive.
    • Pull the optical drive straight from the laptop.
结论
4等其他人完成本指南。
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 13
总计 4,685
