跳转到主内容
Dell Inspiron 1525 ExpressCard Cage Replacement
你所需要的
  1. Dell Inspiron 1525 ExpressCard Cage Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 ExpressCard Cage Replacement, Central Control Cover: 步骤 3 中的图像 1,1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 4 中的图像 3,3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 5 中的图像 3,3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
  6. Dell Inspiron 1525 ExpressCard Cage Replacement, Keyboard: 步骤 6 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement, Keyboard: 步骤 6 中的图像 2,2
    • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
    • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
  7. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to gently lift the ribbon cable retaining flap.
    • Disconnect the ribbon cable.
    • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
  8. Dell Inspiron 1525 ExpressCard Cage Replacement, Bottom Cover: 步骤 8 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement, Bottom Cover: 步骤 8 中的图像 2,2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  9. Dell Inspiron 1525 ExpressCard Cage Replacement, Display Assembly: 步骤 9 中的图像 1,3 Dell Inspiron 1525 ExpressCard Cage Replacement, Display Assembly: 步骤 9 中的图像 2,3 Dell Inspiron 1525 ExpressCard Cage Replacement, Display Assembly: 步骤 9 中的图像 3,3
    • Disconnect the five antennas from their respective cards.
    • De-route the antennas from their routing retainers.
  10. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 10 中的图像 1,1
    • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
  11. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 11 中的图像 1,3 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 11 中的图像 2,3 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 11 中的图像 3,3
    • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
    • Carefully release the connector from its retaining tabs.
  12. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 12 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 12 中的图像 2,2
    • Push the antenna wires up through their hole in the bottom case half.
    • Release the antennas from their retaining tabs on the upper case.
  13. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 13 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 13 中的图像 2,2
    • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
    • Free the ribbon cable from its retaining clips.
  14. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 14 中的图像 1,1
    • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
    • Remove the display assembly from the laptop.
  15. Dell Inspiron 1525 ExpressCard Cage Replacement, Upper Case: 步骤 15 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement, Upper Case: 步骤 15 中的图像 2,2
    • Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop.
    • Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
  16. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 16 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 16 中的图像 2,2
    • Use a spudger to pull the touch pad connector latch towards the ribbon cable.
    • Pull the ribbon cable out of the connector.
  17. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 17 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 17 中的图像 2,2
    • Use a spudger to pull the device status LED connector latch towards the ribbon cable.
    • Disconnect the device status LED ribbon cable.
  18. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 18 中的图像 1,3 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 18 中的图像 2,3 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 18 中的图像 3,3
    • Release the ribbon cable in the upper left corner of the laptop from its retaining tabs.
    • Use a spudger to unplug the speaker connector at the top center of the laptop.
    • De-route the speaker wires from their retaining tabs.
  19. Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 19 中的图像 1,2 Dell Inspiron 1525 ExpressCard Cage Replacement: 步骤 19 中的图像 2,2
    • Use the flat end of a spudger to begin lifting the upper case at its front edge.
    • Lift the front edge of the case up until it comes free.
    • Work slowly and be sure not to get any cables caught in the upper case holes and guides.
  20. Dell Inspiron 1525 ExpressCard Cage Replacement, ExpressCard Cage: 步骤 20 中的图像 1,3 Dell Inspiron 1525 ExpressCard Cage Replacement, ExpressCard Cage: 步骤 20 中的图像 2,3 Dell Inspiron 1525 ExpressCard Cage Replacement, ExpressCard Cage: 步骤 20 中的图像 3,3
    • Eject your ExpressCard or ExpressCard dust shield if you want to transfer it to the new ExpressCard cage. Eject the card by pressing it in until it clicks, releasing it, then sliding it out.
    • Remove the 3.80 mm Phillips #1 screw securing the ExpressCard cage.
    • Remove the two 3.70 mm Phillips #1 screws securing the ExpressCard cage.
    • Lift the ExpressCard cage out of its connector.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,519
