跳转到主内容
Dell Inspiron 1525 Central Control Cover Replacement
你所需要的
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 1525 Central Control Cover Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: 步骤 3 中的图像 1,1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 1525 Central Control Cover Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 1525 Central Control Cover Replacement: 步骤 4 中的图像 3,3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 1525 Central Control Cover Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 1525 Central Control Cover Replacement: 步骤 5 中的图像 3,3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,578
