简介
In this guide we will be showing you how to replace the battery on your Dell Inspiron 1525. You don't need any tools for this process.
Flip the computer upside down and locate the battery release switch.
  • Flip the computer upside down and locate the battery release switch.
  • Remember to disconnect any and all power sources when working on any electronic device to prevent damage.
添加评论
Slide and hold the switch away from the lock symbol to release the battery lock.
  • Slide and hold the switch away from the lock symbol to release the battery lock.
添加评论
Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
  • Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
添加评论
结论
3等其他人完成本指南。
Phil Hopkins
于2010年04月18日注册
308 信誉积分
撰写一个指南
团队
Cal Poly, Team 23-101, Johann Spring 2010 Cal Poly, Team 23-101, Johann Spring 2010 的会员
CPSU-JOHANN-S10S23G101
2 名成员
创作了1篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 15
总计 4,474
