简介
This guide will instruct you how to remove your hard drive.
配件
无需配件。
  1. Rotate the laptop so its bottom is facing up.
    • Rotate the laptop so its bottom is facing up.
  2. Identify the lock mechanisms holding the battery in place. Slide each button outward with your fingers to disengage the battery. Pull the battery off with your hand to separate it from the laptop.
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  4. Locate the four 4 mm Phillips #1 screws that secure the hard drive to the laptop. Each of the screws has a white cylinder next to it. Remove these four screws with a Phillips #1 screwdriver.
    • Locate the four 4 mm Phillips #1 screws that secure the hard drive to the laptop. Each of the screws has a white cylinder next to it.
    • Remove these four screws with a Phillips #1 screwdriver.
  5. Once you've made sure all four screws are removed slide the hard drive out with your hand. Once you've made sure all four screws are removed slide the hard drive out with your hand. Once you've made sure all four screws are removed slide the hard drive out with your hand.
    • Once you've made sure all four screws are removed slide the hard drive out with your hand.
结论
3等其他人完成本指南。
Rogelio Ordonez
于2012年09月26日注册
54 信誉积分
创作了2篇指南
团队
Cal Poly, Team 15-47, Forte Fall 2012 Cal Poly, Team 15-47, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G47
5 名成员
创作了9篇指南
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 10
总计 3,138
