简介
This guide will show you how to remove and replace the battery in your laptop.
  1. Rotate the laptop so its bottom is facing up.
    • Rotate the laptop so its bottom is facing up.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Identify the lock mechanisms holding the battery in place. Slide each button outward with your fingers to disengage the battery. Pull the battery off with your hand to separate it from the laptop.
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
结论
另外一个人完成了本指南。
Nikolaus Powell
于2012年09月20日注册
414 信誉积分
创作了3篇指南
团队
Cal Poly, Team 15-47, Forte Fall 2012 Cal Poly, Team 15-47, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G47
5 名成员
创作了9篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 1,208
