跳转到主内容
Dell Inspiron 1501 Wireless Mini-Card Replacement
你所需要的
  1. Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Wireless Mini-Card Replacement, Hinge Cover: 步骤 2 中的图像 1,2 Dell Inspiron 1501 Wireless Mini-Card Replacement, Hinge Cover: 步骤 2 中的图像 2,2
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 步骤 3 中的图像 1,3 Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 步骤 3 中的图像 2,3 Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Wireless Mini-Card Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 1501 Wireless Mini-Card Replacement: 步骤 4 中的图像 2,2
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 1501 Wireless Mini-Card Replacement, Wireless Mini-Card: 步骤 5 中的图像 1,2 Dell Inspiron 1501 Wireless Mini-Card Replacement, Wireless Mini-Card: 步骤 5 中的图像 2,2
    • Remove the two wires from their connections.
    • Pull the metal tabs securing the wireless mini-card to the back of the laptop until the card pops up.
    • Remove the wireless mini-card from the laptop.
结论
Don Dao
于03/01/18注册
361 声望
创作了4篇指南
团队
一条评论
I have a computer like this. I have a problem that I have not been able to find a solution too. A few parts that support the screen are broken, and I need to know if I will not be able to replace the CPU in the future should I ever decide to cement these specific parts together.
Let me know if you need any more information!
Peter C.
Peter Chapin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 684
