跳转到主内容
Dell Inspiron 15-7567 Wireless Card Replacement
你所需要的
  1. Dell Inspiron 15-7567 Wireless Card  Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 2 中的图像 2,2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 3 中的图像 1,1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 4 中的图像 2,2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 6 中的图像 1,1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: 步骤 7 中的图像 1,2 Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: 步骤 7 中的图像 2,2
    • Remove the 3mm screw using the Phillips #0 screwdriver in the location shown.
    • Remove the grey panel as well.
  8. Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 8 中的图像 1,1
    • Detach the black and white wires connected to the card by gently lifting up on the wires.
  9. Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 15-7567 Wireless Card  Replacement: 步骤 9 中的图像 2,2
    • Gently pull the wireless card out at an angle towards you.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 845
