跳转到主内容
Dell Inspiron 15-7567 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-7567 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,2 Dell Inspiron 15-7567 Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Remove the four 5mm screws with a Phillips #1 screwdriver.
  8. Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 8 中的图像 3,3
    • Remove the cable from the motherboard that is attached to the Hard Drive.
    • Use your fingers or the plastic opening tools to gently pull up on the clip, freeing the cable.
  9. Dell Inspiron 15-7567 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Lift and remove Hard Drive.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 29
总计 1,373
