简介
This guide will demonstrate how to replace the keyboard for the Dell Inspiron 15-7559. This may be necessary if you are unable to use the keyboard.
你所需要的
Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
10等其他人完成本指南。
2指南评论
How to put it back
Using Name - 回复 分享
Do the steps in reverse order, like it says at the end of the tutorial
