跳转到主内容
Dell Inspiron 15-7559 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7559 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-7559 Keyboard Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-7559 Keyboard Replacement: 步骤 3 中的图像 3,3
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
结论
9等其他人完成本指南。
团队
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 的会员
UWT-LINER-F17S3G2
5 名成员
创作了9篇指南
2条评论
How to put it back
Using Name - 回复
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 32
总计 7,183
