跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 15-7559 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-7559 Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
    询问修复机器人
  2. Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
    询问修复机器人
  3. Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
    询问修复机器人
  4. Dell Inspiron 15-7559 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Locate the hard drive on the bottom right side of the laptop.
    询问修复机器人
  5. Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Unscrew the 4 x 2.5mm x 5mm screws, using the Philips #1 screwdriver.
    询问修复机器人
  6. Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 15-7559 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Using your hands, raise the hard drive far enough to disconnect the cables attached to it.
    • Using your hand grab the black portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
    询问修复机器人
结论
3等其他人完成本指南。
团队
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 的会员
UWT-LINER-F17S3G2
5 名成员
创作了9篇指南
2指南评论
Is there a step related to removing the hard drive mount? I believe that you’ll need the mount in order to screw a new drive into the system.
David Trang - 回复 分享
Are there other options beside the same seagate hard drive? I’m reading on forums that this hard drive is not very reliable. And since mine just completely died after less than 4 years I’m skeptable replacing it with the same exact hard drive?
Tee Rivera - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 70
总计 9,546
