跳转到主内容
Dell Inspiron 15-7559 Display Replacement
你所需要的
  1. Dell Inspiron 15-7559 Display Replacement, Display: 步骤 1 中的图像 1,3 Dell Inspiron 15-7559 Display Replacement, Display: 步骤 1 中的图像 2,3 Dell Inspiron 15-7559 Display Replacement, Display: 步骤 1 中的图像 3,3
    • This next step will likely cause some of the tabs, that hold the display, to snap. They will still function and hold the display in place and there should be no noticeable issues once put back together, but the tabs will have permanent damage and repeated disassembly will most likely require replacement.
    • Using the metal or plastic spudger pry open the frame around the display.
  2. Dell Inspiron 15-7559 Display Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7559 Display Replacement: 步骤 2 中的图像 2,2
    • Pull the screen down and let it lie on the keyboard.
  3. Dell Inspiron 15-7559 Display Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-7559 Display Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-7559 Display Replacement: 步骤 3 中的图像 3,3
    • Locate the wire that connects the display to the back panel. There will be a sticker with a qr code on it.
    • Peel the the sticker and pull it back to disconnect the cables.
  4. Dell Inspiron 15-7559 Display Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7559 Display Replacement: 步骤 4 中的图像 2,2
    • The display is now fully disconnected, you can now completely remove it from the computer.
结论
4等其他人完成本指南。
Mason Ottinger
于10/18/17注册
227 声望
撰写一个指南
团队
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 的会员
UWT-LINER-F17S3G2
5 名成员
创作了9篇指南
3条评论
How do you replace the antenna cables around the display?
Prasanna Pokharel - 回复
There are also six Phillips head screws (size 00) around the screen that have to be removed before you can flip the LCD forward.
Ken Schoenberg - 回复
I encountered 4 phillips screws, and the bezel was slightly different. Did not impact ability to replace screen
Teddy Vandenberg - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 136
总计 13,040
