跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 15-7559 Back Panel Replacement
你所需要的
  1. Dell Inspiron 15-7559 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
    询问修复机器人
    添加评论
  2. Dell Inspiron 15-7559 Back Panel Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15-7559 Back Panel Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15-7559 Back Panel Replacement: 步骤 2 中的图像 3,3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
    询问修复机器人
    添加评论
  3. Dell Inspiron 15-7559 Back Panel Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-7559 Back Panel Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-7559 Back Panel Replacement: 步骤 3 中的图像 3,3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
    询问修复机器人
    添加评论
结论
To reassemble your device, simply press the back panel on until all pins snap back into place and then screw the back panel back on.
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 的会员
UWT-LINER-F17S3G2
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 41
总计 3,889
