跳转到主内容
Dell Inspiron 15-7548 Speaker Replacement
你所需要的
  1. Dell Inspiron 15-7548 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 15-7548 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Speaker Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7548 Speaker Replacement: 步骤 2 中的图像 2,2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Speaker Replacement, Battery: 步骤 3 中的图像 1,2 Dell Inspiron 15-7548 Speaker Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Speaker Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7548 Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Remove the ribbon cable by pulling it out.
  6. Dell Inspiron 15-7548 Speaker Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 15-7548 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the compression caps by using the spudger.
  7. Dell Inspiron 15-7548 Speaker Replacement: 步骤 7 中的图像 1,1
    • Untangle the wire from the plastic clips and remove the speakers from the device.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 876
