跳转到主内容
Dell Inspiron 15-7548 Motherboard Replacement
你所需要的
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7548 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the motherboard.
结论
Michael Nunez
于04/12/22注册
325 声望
创作了2篇指南
团队
IUPUI, Team 3-3, Beck Spring 2022 IUPUI, Team 3-3, Beck Spring 2022 的会员
IUPUI-BECK-S22S3G3
4 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 715
