跳转到主内容
Dell Inspiron 15-7548 Battery Replacement
你所需要的
  1. Dell Inspiron 15-7548  Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 15-7548  Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548  Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-7548  Battery Replacement: 步骤 2 中的图像 2,2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548  Battery Replacement, Battery: 步骤 3 中的图像 1,2 Dell Inspiron 15-7548  Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548  Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7548  Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
结论
4等其他人完成本指南。
一条评论
Little grey piece on the cable popped off, will that affect anything? Laptop isn’t recognizing that it has a battery after I took it out and put it back in.
Taylor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 21
总计 2,636
