跳转到主内容
Dell Inspiron 15-7547 WiFi Card Replacement
你所需要的
  1. Dell Inspiron 15-7547 WiFi Card Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 WiFi Card Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 WiFi Card Replacement, WiFi Card: 步骤 3 中的图像 1,2 Dell Inspiron 15-7547 WiFi Card Replacement, WiFi Card: 步骤 3 中的图像 2,2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 WiFi Card Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7547 WiFi Card Replacement: 步骤 4 中的图像 2,2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 WiFi Card Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-7547 WiFi Card Replacement: 步骤 5 中的图像 2,2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 322
