跳转到主内容
Dell Inspiron 15-7547 Speakers Replacement
你所需要的
  1. Dell Inspiron 15-7547 Speakers Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Speakers Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Speakers Replacement, Speakers: 步骤 3 中的图像 1,3 Dell Inspiron 15-7547 Speakers Replacement, Speakers: 步骤 3 中的图像 2,3 Dell Inspiron 15-7547 Speakers Replacement, Speakers: 步骤 3 中的图像 3,3
    • Orient the computer so that the hinge for the display facing away from you.
    • Start removing the speaker on the left by pushing the speaker in the direction of the tick mark on the 2 outer pegs, then upwards
    • The tick marks on the two marked pegs should indicate the speaker needs to be pushed towards the center of the front of the chassis.
  4. Dell Inspiron 15-7547 Speakers Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7547 Speakers Replacement: 步骤 4 中的图像 2,2
    • Remove the left speaker by pushing the speaker in the direction of the tick mark on the center peg, then upwards
    • The tick mark should indicate towards the middle of the back of the chassis.
  5. Dell Inspiron 15-7547 Speakers Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-7547 Speakers Replacement: 步骤 5 中的图像 2,2
    • Remove the wire connecting the left speaker to the right speaker.
    • The wire is secured by small notches, be careful not to break these.
  6. Dell Inspiron 15-7547 Speakers Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 15-7547 Speakers Replacement: 步骤 6 中的图像 2,2
    • Start removing the right speaker by pushing the speaker in the direction of the tick marks on the 2 pegs closest to the front of the device, and then upwards.
    • These tick marks should indicate towards the middle of the back of the chassis.
  7. Dell Inspiron 15-7547 Speakers Replacement: 步骤 7 中的图像 1,1
    • Remove the right speaker by pushing in the direction of the tick mark on the final peg, and then upwards.
    • This tick mark should point towards the center of the right side of the chassis.
  8. Dell Inspiron 15-7547 Speakers Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 15-7547 Speakers Replacement: 步骤 8 中的图像 2,2
    • Remove the cable connecting the right speaker to the motherboard by pulling towards the front of the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 564
