跳转到主内容
Dell Inspiron 15-7547 RAM Replacement
你所需要的
  1. Dell Inspiron 15-7547 RAM Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 RAM Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 RAM Replacement, RAM: 步骤 3 中的图像 1,3 Dell Inspiron 15-7547 RAM Replacement, RAM: 步骤 3 中的图像 2,3 Dell Inspiron 15-7547 RAM Replacement, RAM: 步骤 3 中的图像 3,3
    • Remove the plastic heat spreader that covers the RAM sticks.
  4. Dell Inspiron 15-7547 RAM Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7547 RAM Replacement: 步骤 4 中的图像 2,2
    • Release the clamps on each side of the RAM sticks by pushing away from the center.
    • When done properly the RAM stick should pop up.
  5. Dell Inspiron 15-7547 RAM Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-7547 RAM Replacement: 步骤 5 中的图像 2,2
    • Pull the RAM stick in a straight line out of the socket.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 286
