跳转到主内容
Dell Inspiron 15-7547 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-7547 Hard Drive Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  4. Dell Inspiron 15-7547 Hard Drive Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-7547 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  5. Dell Inspiron 15-7547 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Lift the hard drive out of the chassis.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 698
