跳转到主内容
Dell Inspiron 15-7537 Wireless Card Replacement
你所需要的
  1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: 步骤 1 中的图像 1,1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: 步骤 4 中的图像 1,2 Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: 步骤 4 中的图像 2,2
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  5. Dell Inspiron 15-7537 Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Disconnect the two antennas (one black and one white) from the wireless card.
  6. Dell Inspiron 15-7537 Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
终点
另外一个人完成了本指南。
Jean Whitmore
于01/22/15注册
984 声望
创作了7篇指南
团队
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G2
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 3,868
