跳转到主内容
Dell Inspiron 15-7537 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15-7537 Keyboard Replacement, Bottom Case: 步骤 1 中的图像 1,1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Keyboard Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
  6. Dell Inspiron 15-7537 Keyboard Replacement, Removing the Keyboard: 步骤 6 中的图像 1,1
    • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
  7. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Flip over the computer and open the display as far as it can go.
    • Use the spudger to remove the keyboard from the palm assembly.
  8. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Gently flip over the keyboard and place it on the palm rest assembly.
    • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
  9. Dell Inspiron 15-7537 Keyboard Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 15-7537 Keyboard Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 15-7537 Keyboard Replacement: 步骤 9 中的图像 3,3
    • Take the keyboard off the palm rest assembly.
结论
11等其他人完成本指南。
Jean Whitmore
于01/22/15注册
984 声望
创作了7篇指南
团队
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G2
4 名成员
创作了8篇指南
3指南评论
Great guide, thanks for the help!
Patrick S - 回复
Thanks It’s Useful
ahmed omar - 回复
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
benton.addison - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 6,917
