简介
By using this guide, you will learn how to remove the back base cover of the computer, which is needed to access the interior of the laptop for the rest of the repair guides.
你所需要的
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
即将完成!
结论
另外一个人完成了本指南。
