跳转到主内容
Dell Inspiron 15-5567 Battery Replacement
你所需要的
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15-5567 Battery Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15-5567 Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15-5567 Battery Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-5567 Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
    Fantastic directions. The photos helped immensely. Thank you for posting this.
    Sl Hanley - 回复
  5. Dell Inspiron 15-5567 Battery Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-5567 Battery Replacement: 步骤 5 中的图像 2,2
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
结论
7等其他人完成本指南。
Saaed Chaudhry
于07/15/20注册
478 声望
创作了2篇指南
团队
一条评论
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 81
总计 8,400
