跳转到主内容
Dell Inspiron 15-5565 Wireless Card Replacement
你所需要的
  1. Dell Inspiron 15-5565 Wireless Card Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Wireless Card Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15-5565 Wireless Card Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15-5565 Wireless Card Replacement: 步骤 2 中的图像 3,3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: 步骤 3 中的图像 1,2 Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Wireless Card Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-5565 Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: 步骤 5 中的图像 1,2 Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: 步骤 5 中的图像 2,2
    • Remove the single screw securing the wireless card bracket using a Phillips #00 screwdriver.
    • Slide the bracket to remove it.
    • Disconnect the two cables from the wireless card.
  6. Dell Inspiron 15-5565 Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Slide out the wireless card to remove it from its slot.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 17
总计 158
