跳转到主内容
Dell Inspiron 15-5559 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-5559 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-5559 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
结论
4等其他人完成本指南。
Kyla Ward
于03/19/18注册
649 声望
创作了4篇指南
团队
Baylor, Team S5-G5, Williams Spring 2018 Baylor, Team S5-G5, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G5
3 名成员
创作了5篇指南
2条评论
The blue part came off is that important?
walterandradeconde - 回复
can i put this in a harddrive enclosure?
chiggly 123 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 26
总计 5,471
