跳转到主内容
Dell Inspiron 15-5558 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15-5558 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15-5558 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Identify the two small slots along the side of the keyboard closest to the screen.
    • Wedge the spudger in the two small slots and push the spudger in and down to detach the pins.
    • Using your hands, pull the keyboard up and out.
  5. Dell Inspiron 15-5558 Keyboard Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 15-5558 Keyboard Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 15-5558 Keyboard Replacement: 步骤 5 中的图像 3,3
    • At the end of the ribbon cable attaching the keyboard to the device is a bar secure.
    • Using your finger or spudger, flip the bar up and the keyboard will be freed from the device.
结论
5等其他人完成本指南。
Adam Lourenco
于10/19/17注册
793 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 UMass Dartmouth, Team S3-G4, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 1,939
