跳转到主内容
Dell Inspiron 15-5558 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-5558 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Hard Drive Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15-5558 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,3 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,3 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 Hard Drive Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 15-5558 Hard Drive Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 15-5558 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
结论
4等其他人完成本指南。
Adam Lourenco
于10/19/17注册
793 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 UMass Dartmouth, Team S3-G4, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 42
总计 4,929
