跳转到主内容
Dell Inspiron 15-5558 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 15-5558 Display Assembly Replacement, Note the Antenna Cable: 步骤 1 中的图像 1,1
  2. Dell Inspiron 15-5558 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 2 中的图像 1,2 Dell Inspiron 15-5558 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 2 中的图像 2,2
    • Lift the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15-5558 Display Assembly Replacement, Note the Display Cable: 步骤 3 中的图像 1,1
    • Note the display cable routing and remove the cable from its routing guides.
  4. Dell Inspiron 15-5558 Display Assembly Replacement, Turn the Computer Over: 步骤 4 中的图像 1,1
    • Turn the computer over.
    • Open the display at an angle of 90 degrees.
  5. Dell Inspiron 15-5558 Display Assembly Replacement, Placing the Computer: 步骤 5 中的图像 1,1
    • Place the computer on the edge of the table so that the palm-rest assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  6. Dell Inspiron 15-5558 Display Assembly Replacement, Remove the Screws: 步骤 6 中的图像 1,1
    • Remove the screws that secure the display hinges to the palm-rest assembly.
  7. Dell Inspiron 15-5558 Display Assembly Replacement, Lifting the Display Assembly: 步骤 7 中的图像 1,1
    • Lift the display assembly off the palm-rest assembly.
  8. Dell Inspiron 15-5558 Display Assembly Replacement, Placing the Palm Rest Assembly: 步骤 8 中的图像 1,1
    • Place the palm-rest assembly at the edge of the table with the coin-cell battery facing away from the edge.
  9. Dell Inspiron 15-5558 Display Assembly Replacement, Align the Screw Holes: 步骤 9 中的图像 1,1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  10. Dell Inspiron 15-5558 Display Assembly Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 15-5558 Display Assembly Replacement, Route the Display Cable: 步骤 11 中的图像 1,1
    • Close the display and turn the computer over.
    • Route the display cable through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 15-5558 Display Assembly Replacement, Slide the Display Cable: 步骤 12 中的图像 1,1
    • Slide the display cable to the connector and press down on the latch to connect the display cable to the system board.
  13. Dell Inspiron 15-5558 Display Assembly Replacement, Routing the Antenna Cable: 步骤 13 中的图像 1,1
    • Route the antenna cable through the routing guides on the palm-rest assembly.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 1,995
