跳转到主内容
Dell Inspiron 15-5552 Memory Replacement
你所需要的
  1. Dell Inspiron 15-5552 Memory Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Memory Replacement: 步骤 2 中的图像 1,1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Memory Replacement: 步骤 3 中的图像 1,1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Memory Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-5552 Memory Replacement: 步骤 4 中的图像 2,2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Memory Replacement, Screw Location: 步骤 5 中的图像 1,1
    • Flip the device on its back, locate the screws circled.
  6. Dell Inspiron 15-5552 Memory Replacement, Screw Removal: 步骤 6 中的图像 1,1
    • Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
  7. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 步骤 7 中的图像 1,3 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 步骤 7 中的图像 2,3 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 步骤 7 中的图像 3,3
    • Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
  8. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: 步骤 8 中的图像 1,2 Dell Inspiron 15-5552 Memory Replacement, RAM Removal: 步骤 8 中的图像 2,2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  9. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: 步骤 9 中的图像 1,2 Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: 步骤 9 中的图像 2,2
    • Remove the dislodged up RAM by pulling it away from the connection.
    • If it does not pop up, pry it out in a steady and straight direction.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 273
