简介
The following guide will give instructions on how to properly replace the RAM/Memory on your Dell Inspiron 15-5552.
你所需要的
Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
即将完成!
结论
