跳转到主内容
Dell Inspiron 15-5552 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15-5552 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Keyboard Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-5552 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,2 Dell Inspiron 15-5552 Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Keyboard
    • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
  6. Dell Inspiron 15-5552 Keyboard Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 15-5552 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
  7. Dell Inspiron 15-5552 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Flip the keyboard over onto the palm-rest assembly.
  8. Dell Inspiron 15-5552 Keyboard Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 15-5552 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
结论
另外一个人完成了本指南。
一条评论
After reading this it took all of 5 minutes to remove the key board thank you now to see why this computer will not power up!!!
Ronald Giles - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 233
