跳转到主内容
Dell Inspiron 15-5552 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-5552 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,2 Dell Inspiron 15-5552 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Use a JIS #0 screwdriver to unscrew the two 6 mm screws from the back panel.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  6. Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Using a spudger, lightly lift the RAM cover up and at an angle, away from the computer.
  7. Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the four 6 mm JIS #0 screws from the hard drive.
  8. Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Lift hard drive out of the computer slightly.
    • Be careful not to tear the ribbon that attaches the hard drive to the computer when lifting it.
  9. Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 15-5552 Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Using two fingers, grab the black connector on the ribbon, and pull until detached.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 393
