跳转到主内容
Dell Inspiron 15-5552 Battery Replacement
你所需要的
  1. Dell Inspiron 15-5552 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Battery Replacement: 步骤 2 中的图像 1,1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15-5552 Battery Replacement: 步骤 4 中的图像 2,2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 237
