跳转到主内容
Dell Inspiron 15-5547 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Use the Jimmy to pry and detach the keyboard from the laptop at the following locations.
    • Lift the keyboard from the top and gently detach it from the bottom end.
    • Be careful not to pull too quickly in order to avoid damage to the keyboard connector ribbon cables.
  2. Dell Inspiron 15-5547 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-5547 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Detach the smaller ribbon cable from the laptop connector base by gently pulling upward on the connector base. This will free the ribbon cable.
    • Detach the larger ribbon cable from the laptop connector base in the same manner as the first. This will completely detach the keyboard from the laptop.
    • Be careful when detaching and removing the ribbon cables so as not to tear or damage them.
结论
4等其他人完成本指南。
Faiq Huzir
于05/22/19注册
121 声望
撰写一个指南
团队
IUPUI, Team S1-G3, Harley Summer 2019 IUPUI, Team S1-G3, Harley Summer 2019 的会员
IUPUI-HARLEY-SU19S1G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 869
