跳转到主内容
Dell Inspiron 15-5547 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-5547 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Flip the laptop on its top so that the back is facing up as seen in the picture.
    • Using a Phillips #0 screwdriver, remove the two screws.
  2. Dell Inspiron 15-5547 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using an iFixit Opening Tool, pry open the back panel through the small notch.
  3. Dell Inspiron 15-5547 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the four screws securing the hard drive.
  4. Dell Inspiron 15-5547 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift the hard drive out of the dock and unplug from the motherboard.
    • Be careful so as to not damage the cable.
  5. Dell Inspiron 15-5547 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the four screws located on the side of the chassis to free the hard drive from the bracket.
    • Remove the hard drive from the bracket.
结论
Nicholas Nafziger
于11/04/19注册
266 声望
创作了2篇指南
团队
IUPUI, Team S1-G2, Harley Fall 2019 IUPUI, Team S1-G2, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S1G2
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,253
