跳转到主内容
Dell Inspiron 15-5547 Battery Replacement
你所需要的
  1. Dell Inspiron 15-5547 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 15-5547 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 15-5547 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the laptop on it's top and lay to a rest position.
    • Using the Phillips J0 screwdriver, remove the two indicated screws.
  2. Dell Inspiron 15-5547 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the spudger to carefully remove the back cover to get into the internals. Stick the spudger into the slot indicated in the photo by the marker.
    • Pry up from the slot, then pry up around the sides of the panel. The panel can then be removed by lifting the side with the slot and puling in that direction.
  3. Dell Inspiron 15-5547 Battery Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips J0 screwdriver in order to remove the screws indicated by the markers in the picture. It will be a total of 5 screws. Careful not to puncture the battery.
    • Carefully remove the battery by puling on the black tab.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 2,187
