跳转到主内容
Dell Inspiron 15-3543 Touchpad Replacement
你所需要的
  1. Dell Inspiron 15-3543 Touchpad Replacement, Touchpad: 步骤 1 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement, Touchpad: 步骤 1 中的图像 2,2
    • Flip the device over so the bottom is facing up.
    • Using a #0 Phillips screwdriver, remove the 4.0mm screw to the right of the disk drive.
  2. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 2 中的图像 2,2
    • Pull the disk drive out and sit it to the side.
  3. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 3 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of the device beside the vents.
  4. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 4 中的图像 3,3
    • Slide the panel off by placing your hands on top and, while using a little force, sliding your hands down.
  5. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 5 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw beside the black pull tab on the hard drive to the bottom left of the device.
  6. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 6 中的图像 2,2
    • Pull the black tab up and to the left to completely remove the hard drive.
    • Sit the hard drive to the side once it is out.
  7. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 7 中的图像 2,2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  8. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 8 中的图像 2,2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  9. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 9 中的图像 2,2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out and sit the keyboard to the side.
  10. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 10 中的图像 2,2
    • Push the two battery locks outwards.
  11. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 11 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 11 中的图像 2,2
    • Pull the top of the battery up and out.
    • Sit the bettery to the side once it is out.
  12. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 12 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 12 中的图像 2,2
    • Remove the following ten screws with a #0 Phillips screwdriver:
    • Two 8.0mm screws.
    • Eight 4.0mm screws.
  13. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 13 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 13 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the three 4.0mm screws on the front where the keyboard used to be.
  14. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 14 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 14 中的图像 2,2
    • On the front of the device, there will be two ribbon cables. Remove them using the following directions:
    • Pull the black cable ribbon lock up and pull the blue ribbon out using the tab.
    • Pull the white cable ribbon lock up and pull the blue ribbon out using the tab .
  15. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 15 中的图像 1,3 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 15 中的图像 2,3 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 15 中的图像 3,3
    • Using the one or two opening tools, pry the bottom of the top plate off starting underneath the headphone jack.
  16. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 16 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 16 中的图像 2,2
    • Continue going around the device and prying it open until the top panel is off.
  17. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 17 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 17 中的图像 2,2
    • On the inside of the top panel, pull the black ribbon cable lock up and pull the ribbon cable out using the tab.
  18. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 18 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 18 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the three 1.0mm screws.
  19. Dell Inspiron 15-3543 Touchpad Replacement: 步骤 19 中的图像 1,2 Dell Inspiron 15-3543 Touchpad Replacement: 步骤 19 中的图像 2,2
    • Pull the metal plate up and out from the top.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,444
