跳转到主内容
Dell Inspiron 15-3543 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-3543 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15-3543 Keyboard Replacement: 步骤 3 中的图像 2,2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
结论
2等其他人完成本指南。
1指南评论
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 1,339
