跳转到主内容
Dell Inspiron 15-3531 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15-3531 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 15-3531 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 15-3531 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,3 Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,3 Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: 步骤 2 中的图像 3,3
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard with a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting it out because there is a cable connecting the keyboard to the laptop.
  3. Dell Inspiron 15-3531 Keyboard Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-3531 Keyboard Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-3531 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
结论
另外一个人完成了本指南。
Kody Dahlke
于02/15/18注册
730 声望
创作了5篇指南
团队
USF Tampa, Team S1-G5, Leahy Spring 2018 USF Tampa, Team S1-G5, Leahy Spring 2018 的会员
USFT-LEAHY-S18S1G5
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 549
