跳转到主内容
Dell Inspiron 15-3531 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 2,3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 3,3
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel from the laptop using the spudger.
  3. Dell Inspiron 15-3531 Hard Drive Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15-3531 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Lift the access panel away from the laptop to reveal the hard drive on the left.
    • Remove the two 8.65 mm screws on the left side of the hard drive using the PH0 head screwdriver.
    • There is a plastic tab beneath the hard drive.
  4. Dell Inspiron 15-3531 Hard Drive Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 15-3531 Hard Drive Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 15-3531 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Push the hard drive to the left to release it and use the tab to pull it free from the laptop. The hard drive is in a caddy.
    • Remove the two 1.22 mm screws holding the hard drive in the caddy with the PH0 head screwdriver.
结论
Kody Dahlke
于02/15/18注册
742 声望
创作了5篇指南
团队
USF Tampa, Team S1-G5, Leahy Spring 2018 USF Tampa, Team S1-G5, Leahy Spring 2018 的会员
USFT-LEAHY-S18S1G5
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 34
总计 1,119
