跳转到主内容
Dell Inspiron 15-3521 Wireless Card Replacement
你所需要的
  1. Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: 步骤 1 中的图像 1,3 Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: 步骤 1 中的图像 2,3 Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: 步骤 2 中的图像 1,3 Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: 步骤 2 中的图像 2,3 Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: 步骤 2 中的图像 3,3
    • Flip laptop right side up
    • Using a flat head screwdriver, depress locking tabs holding keyboard into place
    • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
    • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
  3. Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: 步骤 3 中的图像 1,3 Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: 步骤 3 中的图像 2,3 Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: 步骤 3 中的图像 3,3
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
  4. Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: 步骤 4 中的图像 1,3 Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: 步骤 4 中的图像 2,3 Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: 步骤 4 中的图像 3,3
    • Remove the wireless card cables powering the wireless card
    • Unscrew the wireless card using a PH0 screwdriver.
    • Replace with a new wireless card, reattaching the power cables.
结论
7等其他人完成本指南。
Andrew Dippre
于10/13/14注册
2,902 声望
创作了7篇指南
团队
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G1
4 名成员
创作了9篇指南
2条评论
On an Insperion 15 model 3878, the Wi-Fi adapter wasn't under the keyboard. It was under the inset cover on the bottom.
I reseated the card connection and then Windows could communicate to configure it.
Student4Life - 回复
its wlan is right now 2.4ghz. i want to upgrade it to 5ghz. please suggest a solution!
rohit nair - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 31
总计 6,176
