跳转到主内容
Dell Inspiron 15-3521 RAM Replacement
你所需要的
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: 步骤 1 中的图像 1,3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: 步骤 1 中的图像 2,3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: 步骤 1 中的图像 3,3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: 步骤 2 中的图像 1,3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: 步骤 2 中的图像 2,3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: 步骤 2 中的图像 3,3
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: 步骤 3 中的图像 3,3
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
结论
7等其他人完成本指南。
Andrew Dippre
于10/13/14注册
2,902 声望
创作了7篇指南
团队
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G1
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 29
总计 6,241
