跳转到主内容
Dell Inspiron 15-3521 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 步骤 1 中的图像 1,3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 步骤 1 中的图像 2,3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 步骤 1 中的图像 3,3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 步骤 2 中的图像 1,3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 步骤 2 中的图像 2,3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 步骤 2 中的图像 3,3
    • Loosen the two screws attaching the access door to the laptop body.
    • Using a spudger, pry open the access door from the laptop.
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 步骤 3 中的图像 1,3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 步骤 3 中的图像 2,3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 步骤 3 中的图像 3,3
    • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
    • Loosen and remove these screws using a phillips head screw driver PH0.
    • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
  4. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 步骤 4 中的图像 1,3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 步骤 4 中的图像 2,3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 步骤 4 中的图像 3,3
    • Identify the Hard Drive caddy screws, one on each side of the hard drive casing.
    • Remove these screws using a phillips head PH0 screwdriver.
    • Now, with a new hard drive, attach the caddy/casing using the same screws removed from the old hard drive.
结论
28等其他人完成本指南。
Andrew Dippre
于10/13/14注册
2,902 声望
创作了7篇指南
团队
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G1
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 73
总计 32,838
