跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 15 Ram (Memory Module) Replacement
你所需要的
  1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Ram (Memory Module) Replacement: 步骤 2 中的图像 1,1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 步骤 3 中的图像 1,3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 步骤 3 中的图像 2,3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 步骤 3 中的图像 3,3
    • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
    • Using the plastic opening tool, pry the base cover from the base.
    • Slide the base cover towards you and remove it from the base. Put it aside.
  4. Dell Inspiron 15 Ram (Memory Module) Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 15 Ram (Memory Module) Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 15 Ram (Memory Module) Replacement: 步骤 4 中的图像 3,3
    • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
    • Slide the memory module out of its slot and lift it out of the laptop base.
结论
4等其他人完成本指南。
Edward Pacheco
于03/06/16注册
852 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G8
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 29
总计 7,151
