跳转到主内容
Dell Inspiron 15 Optical Drive Replacement
你所需要的
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 15 Optical Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,2 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 2,2
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
结论
3等其他人完成本指南。
Edward Pacheco
于03/06/16注册
845 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G8
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 4,847
