简介
In this guide, we will be showing you how to remove and replace the Display Assembly.
你所需要的
Disconnect the display cable from the connector on the system board.
Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
Remove the four screws (two on each side) that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
Route the display cable and Mini-Card antenna cables through the routing guides.
另外一个人完成了本指南。
