跳转到主内容
Dell Inspiron 15 Gaming 7567 Hard Drive Replacement
你所需要的
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: The latch on the hard-drive locking connector is fragile. Pulling the latch forcefully may damage the hard-drive locking connector. Exercise care when handling the latch on the hard-drive locking connector.
  1. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Disconnecting the Hard Drive Cable: 步骤 2 中的图像 1,1
    • Using a plastic scribe, lift the latch and use the pull tab to disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Remove the Screws: 步骤 3 中的图像 1,1
    • Remove the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Lifting the Hard Drive Assembly: 步骤 4 中的图像 1,1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Disconnect the Interposer: 步骤 5 中的图像 1,1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Remove the Screws: 步骤 6 中的图像 1,1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Remove the Hard Drive Bracket: 步骤 7 中的图像 1,1
    • Remove the hard-drive bracket off the hard drive.
  7. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Align the Screw Holes: 步骤 8 中的图像 1,1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Replace the Screws: 步骤 9 中的图像 1,1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Connecting the Interposer: 步骤 10 中的图像 1,1
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Align the Screw Holes: 步骤 11 中的图像 1,1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Replace the Screws: 步骤 12 中的图像 1,1
    • Replace the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 15 Gaming 7567 Hard Drive Replacement, Connect the Hard Drive Cable: 步骤 13 中的图像 1,1
    • Connect the hard-drive cable to the system board and close the latch to secure the hard-drive cable.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 3,495
